Is this heater core worth repairing?
sevensandeights
sevensandeights
I continue to open up cans of worms the deeper I get into this "quick little project"
While trying to move the heater box, I pulled a little too hard on the heater hose going into the heater core. The instant it let go I knew what I did (especially since the hose was still attached!!!!!).
Anyways, I don't know much about these things but this seems to be OEM because it's beefy. I've read lots of bad things about aftermarket heater cores. My issue seems like a simple fix but I NEVER want to go back in there again so should I have this fixed or find a new one?
FLCJ8
I would think it would be an easy fix for a radiator shop.
If you decide to go new I'd bet you could easily sell that one.
walkerhoundvm
Typical Know-it-all
I literally just fixed mine. Do you have any experience sweating pipes? Super easy. Propane torch, pipe solder, sweat paste and brush. Sand down both mating faces, brush on paste, heat and apply solder around the joint.
Replacements are generally terrible, a copper one is worth fixing.
Either a rad shop or a friendly plumber will fix it for you.
CJ7Pilot
18436572
If it's brass/copper, YES! Have it repaired, and never look back! You can't get brass heater cores for our Jeeps anymore.
If it's aluminum, it's not worth repairing... aluminum heater cores cost about $30.00, but be prepared to replace it every couple of years.
Mine recently failed after 18 months, and I tried like heck to find a brass replacement, with no success.
Fortunately (I suppose), I had bought my heater core from O'Reilly's, and it came with a lifetime warranty. I ended up installing the warrantied replacement, and I expect I'll have to do it again in a couple of years.
walkerhoundvm
Typical Know-it-all
If you have someone who fix it, bring the back panel+/-box so they align the tubes correctly. Took me a couple tries to get them aligned correctly.
Literally just came in from the garage.
I guess i did good in the spring when I bought a obviously old(because of the origianl box it was sold in)NOS aftermarket brass/copper one at a fleamarket for $10.
Spieg
Be advised that most shops will insist on tearing it apart and redoing the whole thing or they wont offer a warranty. They charge almost as much for those little heater cores as they do for a full size radiator...
GreatCJ8
Charter Member
I had issues with mine & took it out of the loop by connecting the inlet hose to the outlet hose until I can get around to installing the new one I have.
sevensandeights
sevensandeights
I've done that also on another Jeep but this one isn't currently on the road so I just removed it.
I took it to the radiator shop and they soldered the fitting back on but it failed the pressure test. They had a NOS brass/copper one on the shelf though. Cost me $80 but it will last and helps keep a Mom&Pop shop in business.
