- Snohomish
- WA
What are you guys with LS swaps, the truck engines like the LM7, LQ4, LQ9, etc in particular, using for oil pans? The stock stuff? F-body pan? Something aftermarket?
The stock pan on the LQ9 I am finally prepping to swap in hangs pretty low. Probably not much of an actual problem for how I will mostly use the Jeep. But since I will be pulling off the oil pan and front and rear covers to reseal them anyhow, why not replace it with something better while I am in there?
Looking at this one on Amazon: https://www.amazon.com/labwork-302-1-Aluminum-Replacement-1955-1987/dp/B08P1WTTFX
It’s an inexpensive aftermarket pan that doesn’t require modification of the factory windage tray.
Also, did you hook up your factory oil pressure gauge using an oil cooler block off plate in the LS oil pan? What plate and sensor combo did you use?
