LS swap radiators
CamJake
Sandwich
Ma
What is everyone using for their LS swapped CJs? My current set up is a cheapie alum rad/stock fan setup from the previous owner. I have a big Griffin 31x19 with dual Derale fans, but it’s huge and will require liberal grill trimming. Plus it’ll sit just outside of the frame rail which might look kinda odd.
My 5.3 is stock so the Griffin setup might be overkill...
What’s everybody running?
Bad Karma
Captain Sarcasm
Garden Hill, Ontario, Cana
da
I ran a universal Griffin for a while until it started to leak. Then switched to a flex-a-lite that was designed for a CJ. Check out the write up in JPFreek Magazine.
Ron84cj
West Bend
WI
I'm running an aluminum radiator for a Jeep from radiatorexpress.com. It's for the 6 cylinder but I have had zero issues even with no fan shroud. I was stuck in stop and go traffic in Chicago when it was 95 degrees and the temp never rose. They do have a Chevy swap radiator but mine was only a year old so I stuck with it.
CHIEFWAHO
SOA VP
SOA Board Member
Thayer
KS
No personal use with this on our swaps but I've seen a few lately and our next swap will use the
Flex-a-lite 51068LS Aluminum Radiator for Jeep CJ with LS Engine Conversion
Used an aluminum Northern brand CJ/Chev swap radiator. Its been years and there are better options out there now (see above), but the Northern unit has worked great so far.
DirtyB
Crazy Cajun
Port Allen
LA
My LS engine swap is basically stock. Do I really need an upgraded radiator like these? The Northern radiator looks like the cheapest option, but it's only a 2 row. Do I really need a 3 row? I also don't need a transmission cooler as I'm using an AX-15 manual transmission.
Ron84cj
West Bend
WI
I have no idea if the stock radiator it is sufficient. Not sure I would trust that.
