bozemanbob
This is long, but interesting. Hope you'll read it all and offer some advice! Went for a short drive the other day:
1) Start Jeep. Was -5 degrees the night before, and was perhaps only about +10 degrees when I left. No engine heater, FYI.
2) Takes a while to start. Have to pump the gas a bunch. Starts and dies. Does this about three times. This is totally normal.
3) Get it started. Warm it up for about 1 minute.
4) Hit the road. Neighborhood road is 1/2mi long at 25mph, then the next road is 45mph for three miles. Next road is 5 miles at 45-55mph.
5) About 2-1/2 miles after leaving home, I comment to my wife "Smell that strong plastic smell? Wonder what that is?" Then the smell goes away. Make mental note to myself to look under the hood when we get where we're going.
5) Reach destination. Lose traction in the icy parking lot, spin the Jeep and smack the curb smartly with the left tires, but not terribly hard. No damage, I expect.
6) Get out of the Jeep. Wife says "I REALLY smell it now."
7) Pop the hood. Oil is EVERYWHERE on the right side of the engine, backside the right fender well, etc. Oil starts just above and in front of the distributor, and covers the block back from there. The starter is gushed with oil, so is the front driveshaft, the front side of the tranny, top of tranny, side of tranny, bottom of tranny, etc. No oil at ALL on the right side of engine.
No oil leaking from the valve cover, and barely a thin film from the head gasket (This is normal. Gonna need a new head gasket next summer.) The oil filter is CLEAN - no oil on it at all.
Oil pan appears to be tight. Oil sending unit(s) appear to be tight.
8) Check the oil - none present on the stick. Add three quarts to bring it back to normal level. Start the Jeep and look for the gusher and... nothing. No oil coming out anywhere. Pressure is normal after adding oil back in.
9) Head home. When I get there I inspect the snow-covered driveway and find several (three) obvious oil drip patterns. It's very easy to discern the front driveshaft drip pattern. So it's obvious that this has been going on for some time. But everytime I drive somewhere I look under the front for oil leaks and never see more than the usual one or two drips from the oil pan plug (gotta put a gasket on that).
So my question: what the h*ll?!?!?!
I've started it once since, also when it was cold, and haven't seen any oil at all. Tried revving it when it was still pretty cold, then warming it up a while, then revving it again. And still, no oil.
I live 18 miles from work and drive on the freeway. But until I can nail this down and fix I'm not driving it anywhere.
I wonder if this is related to the cold-cold weather? Cracked oil sending unit, but the crack doesn't open up until it's warmed up? Or maybe it's only open when it's cold?
Any clues at all?
Any clues at all?
