MD Juan Tub and fender flares. Anyone solve this?
jmarkel
Scrambled for Life
Fairfax Station
Hi all. I am working to get this tub completed. It is an MD Juan, and while much better than my old tub, it did still require a lot of time to make it right. In this picture, I am holding up a new set of flares and they don't appear to cover very well. Anyone have some better option for me? I won't be running wide tires so I'd like to retain the stock width on whatever I put on there. Thanks.
mchoward48
Venice
I ran into the same issue on my original tub, there’s a ridge on the inside of the fender flare that tucks into the body, you just have to put in one screw at a time and work it in.
walkerhoundvm
Just trying to stay upright
Cave Creek
Is yours straight from MD Juan, or did it come through Willys-Overland? I'm curious if you documented any of the work you had to do. Definitely post up if you figure out a solution for this.
In the next couple of weeks, I'll be starting to help with bodywork on my Willys-Overland tub. It didn't look too terrible, but there are definitely spots that are going to need some sheet metal love. Those wheel wells are a hoot, aren't they?
Tap tap tap tap tap tap tap...
When I put aftermarket replacement flares on my Red Scrambler's OEM body after repainting it, I had the same problem. IIRC, I started at the top middle, and worked outward to the ends, leaving the screws loose until all of them were installed. In that way, I did not have to drill new holes in the body or the flares. But, it was a PIA :shrug::twocents:
jammer1
Maple Hts.
Oh
I did the same process. Had to elongate 2 screws on each of the rear flares.
