Measurements for location of stock CA emissions "check carb" light
JeepScrambler
CJ-oholic
Claflin
KS
I am needing to know if anyone with a factory CA emissions equipped CJ can give me the measurements for the correct placement of the "check carb" light. These measurements need to direct me where to cut the rectangular hole for one of these lights so it is in the correct factory location on the dash. I believe these check engine lights were originally used on 80-83 CJ's equipped with the 151 4 cylinder (someone correct me if I am wrong). My plan is to place a reproduction "check carb" light (courtesy of walkerhoundvm, thanks again!) as the MIL lamp in one of my '84 AK postal CJ8's which is getting an OBD1 4.0/aw4 combo. Thanks for the help!
mssldn
Gooding
ID
It is just a little off the outside of the speaker:
Measured from the side to the bottom far right cover:
Measured from the top to the bottom far right cover:
JeepScrambler
CJ-oholic
Claflin
KS
Perfect! Thank you sir, those are just the measurements I was needing. I appreciate the help!
