- Redmond
- OR
Transfer case clocking- today’s project.
I am using a 3/4” thick clocking ring from Advance Adapters. This ring maintains the hub-centric support like the factory installation. First step was to clearance the three ribs on the 241c front bearing retainer.
This is done so the clocking ring can fully seat. Here’s the area that interferes-
Then the ring can be bolted to the transfer case. I used some old Allen screws, saving the new ones for final installation. This is also a dry fit, once I pull everything apart for painting I’ll seal it all up.
I marked approximately the degree from straight up that each position corresponded to.
I started at the 20 degree position. I think I hit it on the first try! Looks good!
From the bottom it hangs down about 3” and it should fit in the stock skid with the low hanging hump removed.
Time to check driveshaft clearances. Using a piece of pvc and an old retractable shovel handle. Looks good at ride height-
How about at full compression? I measured 4” up-travel before the pumpkin hits the A/C bracket. Moving the shaft upwards I have about 3 1/4” before the shaft gets close to the pan and the trans cooler lines. I’ll reweld the pinion snubber back on and lower the bumps a bit. 3 1/4” isn’t much, about the same as stock, but then this isn’t a rock crawler. This is where more lift becomes beneficial.
