- Coopersburg
- PA
Won’t be much of a build here in PA. Jeeps is mostly done. Been Jeepin for 33 years. Would rather drive them and enjoy them then build at this point. Built enough Jeeps over the years
Nice flex!, I will look. Springs are like new. I saw the part number. May flex it out todayLove your Scrambler! Great find!
Are those springs the Rubicon Express 1444(5 leaf) or 1445 (6 leaf)? Probably painted on the top.
I use the 1445's and love them. Great flex with the spring over.
One thing to check is to do some test flexing on a ramp or similar. I have the Currie tow shackles. Looks like you may have the Daystar version. When I would get into a high flex situation, the tow tab part protruding from the front of the shackles would hit the bumper as it flexed forward. I had to notch my bumper to allow the full suspension travel possible with those springs. I wonder if they made some mods on yours to accommodate that. You can see the notches in my bumper. I may get a new bumper and ditch the tow shackles and not have to cut the bumper.
Below are a couple of flex pics of my Scrambler just before I started my tear down to clean it all up (that's a 30 degree ramp very steep)
Also added a traction bar on the rear axle to control spring wrap.
Have fun with your new toy!
George
6 pack
I will check out the rear bump stops. I noticed the front has custom bump stops on it. Thanks for all the infoAlso, you are setup nearly identically to me. I also have a 1" body lift and 35x12.50 BFG MT's. So you are capable of some serious flex.
In one of your pics, it looks like you have the stock bump stops in the rear. You can see it in the snip I took below. Then you can see my extended bump stop. Even with that extended, I still had the tires get into the body on full flex. You can see in my body tub pic, where it is bent at the lower edge and even where I trimmed it.
Just be aware of that and deal with it if you will off road it on any significant trails. I would hate to see that clean body get damaged!
Hope that helps...
GeorgeView attachment 83940View attachment 83941View attachment 83942
