Ok,
Got the brakes to kinda work. I can squeal the tyres, but I think I need a pro portioning valve. I have to push the pedal to more than halfway down in order for it to bite. The top half of the travel is very light, like you're taking up slack.
Got her passed for rego, just need to get some money to rego her now!
Coilover diff mounts moved,
New coils on order (when I can afford to send the originally incorrect ones back)
I think I need 3 inch bumps, not 4 for my height. I'm trying to keep it low but with 35s it's proving difficult. I've already cut the guards and raised to flares, that gave me some much needed clearance, but still might have to go up.
Need a longer Nissan pitman arm. The stock go is too short resulting in too large a turning circle.(about 1" from the turning stops)
Redo the paint, possibly properly or at least stripped back and rattle canned properly.
Front shaft needs to be made.
Find out what is clinking when I brake - not sure if the RE joints are fun ar or the trans/engine is moving.
Wire up a speedo- the autometer gauge is either faulty or I haven't done the wiring for the elec speedo sensor correctly.
Fix the holes in the jeep.
Fix the a/c unit- means I'm going to cut the middle of the dash out and make a centre console to house the twin sticks, shifter and air vents f/r.
Redo the linings. No headlining, so I'm going to make one up.
Redo the doors- making standard cj fulls doors fit as the world cab door seals are no longer available
The that should be it! Besides a little tinkering here and there. Possibly an engine rebuild as its really tappy when cold. That or swap kin a chev/ t700 combo.
