Can you share what paint you used for the housing and how you got the color between the fins? Assuming you painted the whole housing and then polished off the paint.
Same stuff I use. Amazing paint for a rattle can.VHT Roll Bar & Chassis Paint -- High Heat Coatings
Learn more about this one step epoxy coating that does not require a primer and it?s chemical, corrosion, rust and salt resistant.www.vhtpaint.com
