So some quick google searching turns up as an AMC 20.
What is your opinion on this axle running 37" tires? I suspect that it is a recipe for disaster, but how bad is it?
Thanks!
Meh. You might get away with it, but you'll want to do some turd-polishing. The ring and pinion on the AMC 20 will hold up just fine (it's larger than a Dana 44), but the issue is with the 2-piece axle-shafts. If you upgrade to the 1-piece shafts (which a PO may already have done since they broke so commonly; just check to see if you have a hub on the outside), that'll be one major step, but it's still a 29 spline shaft, so a tad smaller than a 44. But still the same shaft used on the FSJs. The other weakness in the CJ version of this axle was the relatively small area for the tubes to press into the cast differential, combined with simply smaller tubes than the FSJ version. Adding a truss will solve that problem. At that point, assuming you aren't throwing a lot of horsepower at it, and aren't stupid with the gas, I'd chance it with a 37". I have at least one friend running a 37" Bogger on his AMC 20.
