Need a New Fuel Tank.
ddavis
KS
The top of the poly tank on my scrambler has warped and will no longer seal to the sending unit. I have looked online, and I have seen tanks from $75 for an aftermarket steel tank to $375 for an aftermarket poly tank with skid plate.
Does anyone on here have any experience with the cheaper steel tanks? Or, should I replace with a poly tank for more money? Your experience and opinions are appreciated.
Thanks.
scrambler250
Maryville
TN
I bought one of the steel tanks a couple years ago (4wd hardware I think). It's worked out fine so far, no leaks, etc. I replaced a factory steel tank and everything fit like it should. You might want to check the sending units though. I think some of the factory poly tanks were bigger than the steel and would need a different sending unit when switching.
