Need help with Warn 8274-50 battery connections
WildTurkeycj8
richmond
va
OK, getting ready to try and install the 8274-50 for the Oak Ridge run.
Can anybody confirm the positive and negative wiring connections for me?
The insulated wires and caps are already connected...I'm looking for the connection points on the winch for the main (+) lead from the battery and the (-) lead back to the frame (or should it go directly back to the battery?).
I see that under the plastic solenoid cover are four solenoids, each with four terminals on it. I think I know where the postive wire hooks up, but want to get a confirmation.
Thanks in advance!
-Mike
splogue
Norfolk
Va
pirate 4x4
Pirate 4x4 has a great tech write up.
As soon as I find the info again I will post a link.
Here is the link. I is what I used in hooking up mine. I do not recommend the emergency hook up since mine started to smoke a little as soon as I hooked up the positive. The bench test worked great though.
http://www.pirate4x4.com/tech/billavista/8274/8274.htm
Sean
