Scramblin_Jim
- Goodyear
- AZ
OK I'm going soft. 110 and 50% humidity is just getting too hard to take anymore. I am considering installing AC into my '83. Which new systems would you recommend?
Also, I have a lot of heat coming in through the firewall and under the seats. Exhaust system I believe is the cause. I was planning on using exhaust wrap to help keep the heat down as I have already put jute with foil backing under my floor mat. I also have installed heat shields between the floor and the cat and exhaust pipes. Without doing something more to reduce the heat coming into the cab, what good is installing A/C going to be? Any thing else that can be done?
