NV4500 Cross member Mounting Hardware
Crestwood
KY
Anyone know if these bolts thread out or are they hammered out from the bottom? The tab makes me think they hammer out from the bottom but I gave them a couple of hits and they didn't budge. Then put a socket on the bolt head and got no joy. Since this back piece is aluminum I didn't want to go too hard on the hammering or the socket until i knew for sure. Its an early dodge NV4500 if that makes a difference. Thanks!
Crestwood
KY
turned out to be a splined bolt...who knew of such a thing? hole wasn't threaded and the splines just dug in to the aluminum. pressed it out with a ball joint c-clamp. probably tap it and thread a bolt in at reassembly .
