OBDII 4.0L swap tach wiring
Furious
New member
Gig Harbor
WA
New member here. I have a ‘85 CJ7 that I did a 4.0L OBDII swap into and I’m trying to wire up my CJ tach. The engine was out of an early model 2000 TJ and still has a coil and dist ignition. I have an OMIX or Crown tach in it and I’ve tried just about everything. Last wire I tapped was the A7 GY Ignition Coil Driver wire and the tach didn’t budge. I just did a full frame off restoration and this is the last electrical gremlin. Anyone have any idea of whether I can get this tach to work with the OBDII wiring harness or am I stuck with buying aftermarket like speedhut? Thanks.
No answer to your question, but wanted to say “welcome”!
Alaskan Postal nutjob
FORUM MANAGER
I missed this, did you ever manage to figure it out? I never had a tach on my OBDII swap before I went to the Speedhut tach, so I don't know how helpful I can be there. Can you find the speedhut instructions and see what they suggested? Being digital, it could be a completely different. I have a thread on here about my Speedhut install and I might have mentioned where I got tach signal in my thread.
gr8dain
Hater of Electronics
Ashburn
Welcome as well. And I am interested in this as well. Trying to get my 4.0 swap buttoned up and would love to know how to feed my aftermarket tach as well.
Dave The Sparky
Scrambling Across The Pond
Halifax
UK
Usually your coil has 2 connections, one is an ignition feed which will be 12Volts when ignition is on and the other cable is the one that signals to fire the coil and pulses with the revs of the engine as its told to fire the spark..
Its the pulsing one you want, i hope it is anyway as thats the one i am going for in my Chevy swap 😁
CJ-8_Jim
NW Chicago Suburb
IL
Welcometo the board
OEM CJ tachometer won't work as is with later MPI electronics... Something about an eletronic conversion that is needed. That's why HESCO includes a tach in their MPI package
10+ years ago there was an aftermarket seller that was selling converted oem tachs (as he could find cores or you supply him with a core) on ebay for outrageous prices.
FORUM MANAGER
Welcometo the board
Wondering if they're firing the plug on the exhaust stroke to burn off any remaining fuel... I know that became a thing to help with emissions. Maybe that's screwing it up.
Dave The Sparky
Halifax
UK
Not the 4.0 but i thought i would check my tacho would actually work with my 2001 Chevy 4.3 engine, it may help others..
Here is the Crown tacho i bought and its instructions.
20210227_110345_resized.jpg20210227_110358_resized.jpg20210227_110403_resized.jpg20210227_110424_resized.jpg
Dave The Sparky
Halifax
UK
The Chevy manual says the 0.5mm white and black (cable 1847) is the tacho (firing signal) so i dug it out of the harness and stripped some insulation off making sure i didn't actually cut it. If this works it will get a soldered joint.
Dave The Sparky
Halifax
UK
So after giving the tacho 12volts and temporarily wrapping the green tacho signal wire around the Chevy white and black wire it works fine although it does seem to be a constant 100 RPM out with what the OBD reader is saying but thats a cheap thing as well and i can live with 100 RPM.
It appears to be constant throughout the revs so not sure why?
Furious
New member
Gig Harbor
WA
Sorry I haven’t responded sooner. Been busy moving and working on the Jeep. We’re now in Soithern Italy, in COVID lockdown at the moment but I still haven’t gotten the tach to work. Think I’m going to break down and get a new speedhut tach. When can get out I’ll post some pics of the Jeep driving the Amalfi Coast.
Scramblin Man
Beyond help
Woodway
Tx
I have heard that if you convert the original 4.2 to a Mopar MPI kit, you have to use a 4cyl tach to make it work correctly. Not sure if that would apply to a 4.0 ??
Rosco1974
West Haven
UT
I have the same tach on my ODBI 4.0L and the RPMs are off, but it fills the hole and "works"
gr8dain
Ashburn
I am wondering if I look for an aftermarket tach for a 4.0 Cherokee, will it work? And what the instructions say for wiring it up. I really want a working tach for some reason. 😜
