Ospho vs. Naval Jelly
Grand Rapids
We stock Naval Jelly here at work. We can order Ospho out of our warehouse, but have to order a full case to get it. We don't really need the extra product option on the shelves. Does Naval Jelly do a great job, as well?
I have never used anything comparable except POR-15 Metal Ready.
Please discuss.
Craig
I've never liked naval jelly after getting OSPHO. I think that the watery nature of OSPHO is a big plus to get in every little nook and the naval jelly never gave results with the obvious effect and speed I've seen with OSPHO.
I will never be without it again! :D
CBRogers
Perpetual Parts Collector
Yorktown
Va
Home Depot arround here stocks an Ospho knock off from Clean Strip.
I like the thin consistency of Ospho for shooting a nice stripped panel. For heavier rusted metal espically with pits I like the ability to brush on Naval Jell and let it sit. It seems to soak in better.
That being said I like to use muratic acid to clean up rust on the metal to start with.
Eddie a local Fab guy here has a big 6' tub of acid that he dips all of his tube stock prior to welding. Gives a nice clean surface. He is using Muratic in the tub and then after welding and clean up uses a product similar to Ospho but better. It is for commercial use only but I for get the name. Comes in a white gallon bottle with blue and orange lettering. Something like Rust Buster, or similar.
Carl
Grantshire
Pickle-x 20 is the best stuff I have found for getting rid of surface rust. I use the Marhyde rust converter on frames and heavily rusted parts.
CBRogers
Yorktown
Va
So Grantshire you have tried the Picklex-20?
I was wondering how well it worked. Seemed expensive but if it does work then it might be just the thing to use between stripping a body panel and painting it.
Carl
Grantshire
Carl
Yes, I use it and it is the best stuff I have found. Great paint bond too.
