Painless aint Painless
One ton
Fredericksburg
Va
Just thought i would throw this out there, Me and luke ( 53d scrambler) got painless kits # P/N 10110 for or jeeps and both had the front turn signals were wired wrong in the kit, what happend was that when you would turn on the right side the left would blink and Vice versa. had to go in and cut the wires and switch them. Should not have to do that for a 500 dollor item. It was only in the front back was ok. :crazy:
Kane
Berlin
ct
That's it? I expected to hear a big horror story or something.
Jeeperdd
Gordonsville
The other thing is one harness is set up for two or three different engine's. so you end up with a bunch of unused wires in the engine compartment and i'm sure one ton will tell you the instructions that come with these kits are superb!
certifiablejeep
Definitley Certifiable
Bedford
NH
That is too bad, I have used about 6 of them without too many issues... but seeing that it was only 2 wires you had to swap, that isn't too bad.
53D Scrambler
Hampstead
Yea I can't complain. Except for the little issue with the turn signals. You can definitely tell they are wired for a broad range of setups, which is understandable. That has actually helped me because mine has a Howell EFI on it so I was able to use one of the many extra wires to power the computer and other things without cutting/splicing.
It's about as "painless" as wiring a car can be.
