Pedal shims/washers?
gpassida
Silver Member
Redding
Ca
Hello all,
I am cleaning up and rebuilding my brake and clutch pedal assembly.
On both the clutch and brake pedals there is a thin shim or washer that has slight bends in it. Is that normal? Is this some kind of worn down tension spring?
Can new ones be sourced from anywhere?
Can I replace it with a nylon washer?
Thanks!
They are wave washers:
East Norriton
If a local hardware store has bins of hillman nuts/bolts/washer/etc they might have the. The local Ace and True Value near me have wave washers in that section.
gpassida
Silver Member
Redding
Ca
Awesome! I have never seen "wave washers" before. I'll check the local Ace first then I can get the micrometer out and see if the McMaster site has that size.
Thanks!
83CJ-8
Trying to catch up
Lewes
DE
Thanks!
Got mine from Ace Hardware.
