Picture of factory side steps on drivers underside
rispony
Scramblin' in the City
Manhattan
NY
Unfortunately the pictures and diagrams I've found online don't tell you the measurements correctly for the install of the factory side steps
My question, is this notched cutout in the underside intended for the rearmost bolthole in the sidestep?
ImageUploadedByTapatalk1427831892.949286.jpg ImageUploadedByTapatalk1427831902.596532.jpg
rispony
Manhattan
NY
I don't see that notch on mine.
Do you have the factory side steps installed? If they're installed, the mount would cover that notch entirely. The mount is like 2inches wide, and that notch is about 1/2". Can I have a pic if you have one?
rispony
Manhattan
NY
Never mind, pics just loaded finally! It looks like the mount is covering that notch? That helps a ton, I think I'm going to drill right through it?!
Chipster1990
Birmingham
AL
I didn't have to drill at all. The holes were already there. Tell me what you need pictures of and I'll take more!
jerseyjeeps
Crazy about AMC Jeeps
Landing
NJ
The sidesteps were installed on the assembly line kinda haphazardly in my opinion. I've unbolted alot of them in unmolested jeeps and see very rough holes and not necessarily a great bit of quality control. A lot of cases the holes are so jagged it look like they used a regular drillbit, didn't care that the edges or jagged and just slapped them on. if you have the holes from the sidesteps they were likely there from the beginning if you have no sidesteps and never had them you won't have any holes. RisPony, I have a rubbing of a factory set floor pan if you want to make it "exact" before you drill let me know :cheers:
rispony
Manhattan
NY
I'll let that pony joke slide only cause it's April fools....but YEAH, how do I get that rubbing? It's almost impossible to hold up the steps from underneath and mark the holes. Plus the tub is painted, so it's only getting drilled once...That would make my life a lot easier.
