Been a while since my last post. I have the new spring perches on the AMC 20 tacked on. I need to get axles installed so I can mount the disc brake caliper brackets and then I'll be ready to paint it up.
I have a bit of a problem on the Dana 30 spring perches. The passenger side spring perch needs to be mounted with the center pin hole so close to the carrier that this heavy duty spring perch won't fit as is. I'm thinking I am going to have to open up one side of the perch to allow it to sit on top of the carrier housing and just weld it to that. The pictures are probably easier to understand than my description.
Anyone have any other suggestions to fix this?
