Brass, or zinc plated..."steel"?The best I heard is MTS, but not seen the brass ends before. Thanks
They don't as far as I can tell. I've not yanked on them though.Probably Phosphate coated steel - same as you see on high tensile bolts. It protects against corrosion.
Either way they look good, do the ends (pull knobs) come off?
