trent234
- Portland
- OR
Hey guys, first let me say I'm new to most of this so bear with me. so I'm faced with a radiator fan issue. I'm currently running without a radiator fan, and I'm looking to change that. The problem is, there is very little room for a fan to be mounted.
As you can see its tight. Most fans won't fit, but few sites give width dimensions of their fans anyway. I was thinking the stock fan would be the smallest, I found an OEM replacement here-
http://www.quadratec.com/products/51203_01.htm
Would that do the trick? Will that even fit?
I'm running a 258, not sure of the radiator specs although I know its made for a V8.. hence a space issue.
I'm just brainstorming at the moment, any ideas are welcome. Thanks!
-Trent
-Trent
