Roll Bar Removal... with a grinder?
jsteed
Seattle
WA
Probably not going to happen this summer, but when I replace panels over the winter in the bed area, I need to remove the rollbar. For laughs I picked up a couple T40 bits, and fed them to my impact gun. There are 16 torx bolts holding that rollbar in place. 0 moved. I soaked the best looking ones in penetrating oil from above and below. waited 2 days. nothing. Used a couple adapters on a breaker bar and broke the bits, as expected. So, when I replace the bed panels, I'm *considering* just grinding all the heads off... since the crossmembers will likely need to be replaced (at a couple hundred bucks a peice *groan*).
Has anyone else had to do this? I'm certain I'm not alone here...
jsteed
Seattle
WA
Should also note the following:
1) some of the bolts are so corroded, that they're filled with paint and rust and will never accept a bit.
2) whoever invented torx bolts should be tarred and feathered.
rubclt
Charlotte
I have used torch to heat bolts with success followed with slow speed impact gun with heavy downward pressure. A cutoff wheel making slot in top for big screw driver for damaged heads and finally cut head off and drill bolt out starting with small bit and working up... others may have more ideas, good luck.
jsteed
Seattle
WA
I was afraid to use heat on rear ones because of proximity to fuel tank and filler hoses, but I suppose those can be removed (PITA!) Thx for ideas!
CJ8Rockcrawler
The FABLED 8
Minneapolis
MN
The only other things I would add are long soaks with PB Blaster, welding a nut on and attempting to tighten slightly before trying to remove. I've had success with each of those methods in the past.
certifiablejeep
Definitley Certifiable
Bedford
NH
If you are going to be replacing panels, remove the fuel tank and you will be miles ahead with all the sparks that are coming down the line.
Only thing that gets torx bolts out of the rollbar is heat (and a lot of it) up here in New England.
They are always corroded and never want to come out nicely.
TravelnMan
Granby
CT
I had better luck grinding the nut off the bottom on the ones that I couldn't get out. The nut is welded onto the bracket, if you go that route you'd have to decide whether or not to weld them back on.
certifiablejeep
Bedford
NH
The new panels would have the nuts on them if he gets them from classicent
Belizeit
River Ridge
I was lucky also, but then again that was the 3rd time I removed them. Replaced them with different hardware this last time also. Something I could use a socket on image.jpeg
Mancunian
Bridgeport
WV
The two at either outside edge on the front are fun.
I resorted to using a cutting torch centered on the head for one side - just have to be steady8-)
Try grinding the washer out at one side with a dremel - if you can loosen and remove that it reduces the torque required.
KandE
Petaluma
CA
#16
When I'm pulling parts at the salvage yards, I use PB Blaster and then shock the bolts or screws by hitting the tool with a sledge, HARD!. I've been pretty lucky getting things off that way. If that dosent work I would normally grind a slot then move to heat if that fails. With the drought in Cali the yards won't let us grind or torch anything, they have to drag the carcass to the shed and do it for you.
East Norriton
#17
Yards around hear never let you use a torch, probably no cordless grinders either, drought or not(drought hear are NOT like Cali droughts)
#18
No torches or cordless grinders in yards around here either. And some yards don’t allow jacks either.
certifiablejeep
Bedford
NH
#19
Here is an interesting question... I got some parts the other day and in it was a bag of supposed OEM rollbar bolts... the person that I got the parts told me that they were the "true triangular" type bolts.
I just stared and was like, "ummmmmmm".
So, never having heard this before, I took a picture of the shaft of it and these bolts appear to not be perfectly round.
Seeing how I never heard of this, figured I would throw it out there.
I have no idea if it is true or not... and I claim to know nothing of this.
Hard to get a good straight on picture, but this is what I have.
I need to get out there tonight and find one that I removed and see how it looks on the bottom... I don't recall ever looking at it like this, nor do I recall a dimple in the bolt, but the memory... she is old now...
KandE
Petaluma
CA
#20
The bolt heads are always Torxs but the threaded shaft has a slight triangular shape to it. At least my bolts are like that. I think helps to keep the bolt from loosening.
W
