Rugged Ridge steering linkage question
I’ve decided to replace the steering linkage. Looks like the HD Rugged Ridge setup is not that much more than stock parts. I do remember seeing that there were some issues with it, like ends that wear out quickly and are no longer available? I tried the search but no luck.
Belizeit
River Ridge
Just to be clear on this, what are you considering steering linkage ? Tie Rod and drag link ?
Don't buy the Rugged Ridge kit. The rod ends are crap, will wear out fast, and Rugged Ridge is the only source for replacements. And, their warranty does not cover the tie rod ends. I contacted Moog and a few other chassis part manufacturers, no one makes replacements for the Rugged Ridge stuff. I was able to find one end, but not the other.
I am using a kit from OK Tire and Auto. Beefy tubes but they use the stock CJ rod ends, so easy to find replacement parts. Their rod end wore out in 10k miles, so I installed NAPA replacement rod ends, over 30k hard miles, no problems.
Not flipping the rods at this point. Spankrjs, that was what I remembered but couldn’t verify. I think I’ll just stick with the stock setup for now- it should serve me fine with 31” tires.
MomoJeep
Seattle
WA
I've got 265-16R75's right now (32X10). I'm planning to go to 33x12's for summer use. I wonder how long my stock linkage will hold up with 33's.. !?
