Sharing my Audio Plans
TXJEEP
Copper Canyon
Posting this in case anyone is interested in audio upgrades in your scrambler. Everything in my build is bolt into stock scramblers with 2 exceptions:
1. the head unit is single DIN but could be substituted with RetroSound unit
2. the stock alternator output may not support the additional draw on the system. I already replaced my in the build so I did not do the math.
TXJEEP
Copper Canyon
Head unit - Kenwood Excelon KMM-X503
$130
6 RCA Out - 6 Channel Preamp outputs
Front Dash Speakers - 2x Polk Audio DB 522
$80 + $7
5.25 inch 2-way
100 watts RMS
Frequency range 55-22,000 Hz
Sensitivity 91 dB
Mounted behind cutouts in metal dash with Speaker Baffles
Front Floor Speakers - 2x Polk Audio MM 522
$127.50 + $70
5.25 inch 2-way
80 watts RMS
Frequency range 50-40,000 Hz
Sensitivity 92 dB
Mounted in Select Increments Centra-Pod
Behind Seat Speakers - 2x Polk Audio MM 692
$150 + $70
6x9 inch 3-way
150 watts RMS
Frequency range 30-40,000 Hz
Sensitivity 94 dB
Mounted in ABS housings against bulkhead
Amplifier- Crescendo Symphony S6
$425
4-channel at 4ohm x 100 watts
2-channel at 4 ohm x 200 watts
Rated power output at 13.8v
Subwoofer - 1x Polk Audio DB 842 SVC
$80 + $260
8 inch 4-ohm
250 watts RMS
Frequency Response 30-200 Hz
Sensitivity 84 dB
Mounted in Select Increments Intra-Pod Center Console
Amplifier - Kicker 42PXA5001
$200 + $37.50
250 watts RMS x 1 at 4 ohms
Frequency Response 25-120 Hz
Switchable low-pass filter (60, 80, 100 or 120Hz at 24 dB / octave)
KickEQ Bass Boost (Selectable 0dB or +6dB centered at 40 Hz
Fixed subsonic filter (25 Hz, 24 dB / octave)
Fuse 40A x 1
Mounted in Select Increments Intra-Pod Center Console bottom cavity
Wire - 1/0 gauge and 4 gauge = $33.25
In-line Fuse block = $10
Power dist. block = $14
Ground dist. block = $14
Belizeit
River Ridge
That would blow the doors off of anything I’ve ever had ! Envious. You should be able to hear music now at 70 mph with the top off.
Chamba
Not obsessed: focused.
Vero Beach
Impressive. I've never even had a radio in my 8 so you've certainly got me beat. Nice.
Azbball11
Weston
WI
Very nice setup. I started with a retrosound in dash head unit and ended up pulling this out and putting in a Bluetooth amp (ATOM P20) from Rockville. This way I have I ended up with a clean dash (no radio cutout) and put the amp in my console. I also run a Rockville sub (USS10) under the drivers seat. Rockville sounds good and priced right.
Sounds good and everything is hidden and ran through my phone.
tower210
Olathe
KS
Will be interested to see what quality the console/sub box ends up being. Need more pix...
TXJEEP
Copper Canyon
I thought about going with a hidden head unit or retrosound. I ended up replacing all of the heating and AC and installing a restomod air system. This pushed me to get a custom dash from DoubleD fab so that I could cut in proper vents, auxiliary switches and the heat/ ac controls.
dashboard-2-jpg.82887
