Soft top window replacement?
Ron84cj
West Bend
WI
So yeah, this just happened today. It's not like my top is 40 years old and it's only 35 degrees out or anything. 😏 So anyways, it looks like it was glued on from the factory. What do you guys recommend to use as a replacement? Also, what do you use to attach it? Glue or have it sewn on? Thanks.
PXL_20211113_221105335.jpgIt's hard to see in the pic, but the date is 2/14/81PXL_20211113_221114463.jpg
Belizeit
River Ridge
That happened to a door window on mine about 35 years ago when a young punk decided to break some windows on cars with bottles in a parking lot. Other than replacing it, I found nothing at the time to fix them. I ended up using a thick strong 2 inch clear tape to patch it. I will be interested to see if there is anything to fix on the tops.
Jeep Addict
Baton Rouge
There may be a thread on here somewhere about window replacement. I remember someone replacing the windows on a soft top and it looked decent. Maybe try a custom upholstery/convertible top shop.
