It's a standard transmission. The NSS wire was never connected. I did get a test light, but now "where to test?" Batt to starter (coming out of solenoid)? Batt to one or both posts of the solenoid? Ignition switch "on" I suppose?
Posting this image; it looks like this one to me; I will double-check the solenoid ground to the fender well
https://www.google.com/search?site=...4k1.PWbT_moEFP4#imgrc=DQDRb3FTnsoy9M:&spf=484
Thanks!
DR
The mounting bracket for the manual trans. solenoid needs a good ground to operate.
The auto trans, solenoid gets it's ground through the stud (#3 in pic)
If the new solenoid has the terminal for a NSS, and you have a manual, the terminal needs to be permanently grounded.
(The NSS prevents the starter from engaging when the auto is not in park or neutral. When it is in park or neutral the terminal is grounded through the switch.)
This is the manual:
This is the auto:
You can do a couple solenoid tests without assistance with just a jumper wire, but further testing will require the test light and assistance.
* Make sure trans. is in neutral and parking brake is set*
1.) Make sure the solenoid bracket/ground stud has a good ground by attaching a jumper from battery negative to bracket/stud.
2.) Try starting with ignition switch.
2a.) If it cranks, provide proper ground.
3.) If it doesn't start, (leave temp. ground jumper connected) remove wire from "S" terminal on solenoid and momentarily jump battery "+" terminal to solenoid "S" terminal.
3a.) If motor cranks then there is a problem in the ignition switch/wiring.
4.) If it doesn't crank, the solenoid is defective or you have insufficient battery voltage. (unlikely since you were able to crank it previously)
Let us know what your results are and we can move on to the next steps if necessary.
