- Houston
- TX
Need your help. I recently finish restoring my jeep cj8 and closed the door to check if the lock would work(key). Well it sure did. Now, I have not had much time to look into this but I do know it will not open up from the inside or outside. Prior to puting the door interior panel back on I had to slightly bend the two interior door rods in order to keep them from slapping the metal inside the door on every bump. Any help would be apprciated. Thanks
