Tapping Aluminum for Helicoil <<<what a $$$$$>>>
tom82cj8
Scrambler Pro
Austin
What am I doing wrong? I need to install some helicoils in my TF727 tailshaft housing. This is where the D-300 mounts. The holes I need to fix are the bottom two where the tranny mount goes. I have drilled out the original threads using the bit from the Helicoil kit, I can't get the Tap from the same kit to start threading into the Aluminum. The tap starts to load up with aluminum, and then it won't cut. I have tried running the tap by hand, and also in my drill. Cutting fluid is Liquid Wrench. Please give me some tips....
Thanks,
Tom
tom82cj8
Scrambler Pro
Austin
I was reading that one as you replied. I was hoping for an "experienced" response. I have tapped steel many times with great success. I didn't realize the aluminum would pose problems. I actually thought it would be easier because it is softer. I think that the softness makes it more difficult because the tap would rather strip out the new threads than pull itself into the hole.
Thanks,
mysunnshine
Phoenix
Tapping aluminum is a lot like steel but you have to be extremely careful that you don't move the tap as your turning it because it'll just pull the threads that you just cut. I always use WD-40 with aluminum and have good success with it. For some reason cutting oil doesn't work well.
