TF-999 kickdown linkage
EdeC
'84 Ak Postal Scrambler
Seward
Ak
Has anyone ever found anything on adjusting the kick down linkage on a TF-999? I've noticed that my jeep has stopped downshifting automatically when passing and going up hill. Can anyone point me in the right direction?
Thanks
Ed
John N
Rockville
There's not much to it. Check out the linkage to be sure it's not broken or missing a bushing. If it's all there, there are only 2 ways to adjust it and only one screw to loosen and tighten in the linkage. It's done at the carb end; either shorten the linkage or lengthen it. Then test drive it. My guess is that you need to shorten it a little, due to wear.
EdeC
Seward
Ak
That sounds easy. I'll get under there tonight and see if I can't make it worse.
Thanks
mrachal
Conroe
I have a 999 in my Scr. I bought a Kit from a company called LOKAR. They have a cable type kit I also purchased a carb. bracket. When installed it is adjustable at the carb which makes things easy to adjust. Summit Racing handles Lokar.
Mike Rachal
OBXTucker
Yep, you definitely want the LOKAR kit (if you don't already have it). I'm running the same product and I'm almost positive John N is as well.....
John N
Rockville
Nope, I'm still running a pieced together linkage. Stock parts from my Scrambler and pieces from an '80s Waggy. It's working, but the Lokar product is much better than the stock stuff and a difinite upgrade. It's easier to adjust and less trouble overall.
EdeC
Seward
Ak
dumb it down for me
I was going to try to avoid this question by consulting Mr. Chilton but he was no help.
Where is the kick down linkage and what does it look like?
I know what you’re thinking…”This guy doesn’t need to be anywhere near the jeep with a wrench.”
Anyway thanks for the help.
No worries man... we were all there once!
The kickdown linkage is on the drivers side of the carb and connects to the throttle linkage. It runs down from there toward the rear of the jeep, going under the firewall and it connects to a small rod/lever on the tranny. The back part of the linkage is ~.25" round rod and the part that connects to the carb is a piece that has parallel small rods that run from the carb down to a connector with a nut/bolt where it joins the bigger rod. This is where the adjustment is made. You get to it from in the engine bay, not underneath the Jeep.
Here's a pic of the part that connects to the throttle linkage on the carb (the part that's captured by the pin/clip thingy):
and at the very bottom right of this one is the nut/bolt where you adjust it:
EdeC
Seward
Ak
Thanks for all the help.
I adjusted it slightly in both directions and the transmission never downshifted on steep up hills. Then I adjusted it all the way in both directions and still it didn't make a difference. I realize that I went about asking my questions is wrong order but now I'm wondering if the kickdown linkage even does what I think it does (which is downshift on steep hills when the motor begins to bog down in 3rd).
Thanks for the pictures Big Walton.
John N
Rockville
..... now I'm wondering if the kickdown linkage even does what I think it does (which is downshift on steep hills when the motor begins to bog down in 3rd).
It should do that. Make sure the linkage is all connected and not missing any bushings. It sounds like it has too much slack in it.
BigAl
Prattville
AL
Opening an old thread, just finishing an engine rebuild/ trans clean up and a new lockup converter. Looks like I’m missing the front clamp/bolt from the adjusting link. Nearly 8 years later is the Lokar still the way to go? Relatively easy? Thanks in advance.
