- Seattle
- WA
After airing down several times it seems my tires have gone way out of balance. They are Goodyear Dura tracks. They are probably 60% worn down. It’s also possible that the previous balancing weights got knocked off or something like that. I went in and had them re-balanced and they added significantly more weights on one or two of the tires.
So, can airing down throw the tire and wheel out of balance? For example if the air pressure is low enough could the way the tire is mounted to the wheel shift in some way that throws it off balance? Off center?
