under dash a/c
Lake Charles
I just bought a 82 scrambler and have the a/c and was wondering how hard it is to drop the a/c to get to the gauges to change them and put in new bulbs thanks for the help
Kim Dawson
Molalla
Or
Should be 4 or 5 sheet metal screws holding it to the bottom of the dash. Might possibly be another brace, but once you loosen it from the dash you will know. Still the usual twisting and reaching but the ac unit will hang down.
Zodiac
Macomb
MO
It's easier to do as much as you can from the passenger side, even for the screws on the driver's side. I don't know why, but mine was a royal PITA on the driver's side. Be careful you don't kink the AC lines when you lay it down. Getting to the gauges is gonna be a trip; unless you have arms like an orangutan, you'll wind up on your back on the driver's side with one leg up in the doorframe.
Craner8
Orlando
And be careful not to break off the drain hose on the bottom, if you have one. Mine broke at the box and haven’t fixed it yet. Lowered it 6 times to reach the break light switch, and finally just removed the dash bolts and lowered it too. Much easier to reach everything, and really didn’t take too much time.
don87401
Farmington
NM
Pull the seats out just four bolts each then you can lay down a bit more comfortable to reach things.
