Vaccum connections 151 engine
Otto
Boonie Basher
Tomah
WI
Could some one post a picture of the side of their 'rotten-chester' carberator, showing where the vaccum hoses hook up and were they go? :confused: Or explain in words where which hose hooks up to what. The Chiltons nor Haynes show the 151 4cyl in their diagrams.:(
Thanks!
Blzbro
S.O.A. Member
Centerville
IN
My old Iron Duke is sitting in the corner, I will check and see if the vacuum lines are still attached.
Blzbro
S.O.A. Member
Centerville
IN
I don't know how correct these are, but it started and ran, I only ran it a couple of times before I pulled my Scrambler in the barn and tore it down.
Mine has
#1 - hooked to the diaphragm in the front of the picture
#2 - distributor vacuum advance
#3 - is plugged or capped
#4 - goes to vacuum manifold shown in the bottom of the picture
I know there are still a lot of people out there still running their Iron Dukes,
is this correct?
Otto
Boonie Basher
Tomah
WI
found diagram
Thanks for your input. I finally found a vacuum diagram in the mitchel manual .This shows the lines for emissions but not the hookup on the side of the carb. :(
Any one with a running 1981 4 cylinder who could tell me which port the distributer and the choke pulloff hook up to? :confused:
