- Redding
- Ca
Been busy with work but worked in some Scrambler time in-between. This will be an electrical accessory update.
Here is a current picture of the under hood shelf I made and the fuse block, controller and shutoff breaker:
I made the shelf out of 1/2" thick commercial cutting board. Mounted it all on the passenger fender. There is a lot going on here but here is some of the breakdown.
The Redarc BCDC1225D dual battery charge controller is mounted below the dual batteries. It's job is to monitor the second (Aux) battery and keep it charged. Either by the engine or the solar panels. Some pics of those will follow below.
And in order from the battery side to the front end:
- Ground block for the large negative cables. Nearly everything in the Scrambler has a dedicated ground wire.
- Blue Sea Safety Hub 150 - https://www.bluesea.com/products/7748/SafetyHub_150_Fuse_Block
- sPOD Source LT six circuit switch system - https://www.4x4spod.com/sourcelt_modular_w_led_switch_panel_36_battery_cables
- Blue Sea 187 series circuit breaker/cutoff switch: https://www.bluesea.com/products/7148/187-Series_Circuit_Breaker_-_Surface_Mount_150A
The Safety Hub 150 can handle 10 circuits with 280A total. Four of the circuits use MIDI fuses and can be up to 200A each. Then there are six ATC fuses that can handle up to 30A each. All of my planned loads if on at the same time, would draw 147 Amps.
In my use ALL accessory circuits are wired through this and are powered by the Aux battery. This includes the stereo/amp, all auxiliary lights, all nine USB outlets, Dometic refrigerator, Viair Compressor and the GMRS radio. Only the starter, Painless harness and the winch will use the Starter battery.
The sPOD can control six loads up to 30A each from the dash switches. It can also be controlled by a Bluetooth app. One of those is the "Dual Battery" switch that will activate the Solenoid you see on top of the batteries. It will link the two batteries together if I need to do a hard winch pull or jump start myself.
These switches are wired into the headlight switch like the other dash gauge backlights:
And the final device on the shelf is the 150A Blue Sea circuit breaker/cutoff switch. I can throw the yellow lever and disconnect all of the loads on the Safety Hub and sPOD.
Here is a closer up shot of the batteries:
Below the fuse blocks is another mount I made from the cutting board material. It has three MIDI fuses that protect the Redarc charge controller, including the inputs from the solar panels.
Once I add the remaining devices (mostly the lighting) I will clean up and secure the many cables better.
More about the rear outlets in my next post...
