Warn Zeon stick in neutral
Spieg
Aurora
Anyone had this happen or know of a fix?
Yesterday I went to use my winch... first I moved the lever to free-spool and pulled out the line I needed to hookup. Then I moved the lever back to engage. Everything seemed normal except when I power the motor, I can hear it turning and the drum does not move. I can move the drum by hand regardless of the free-spool lever position.
Seems like the motor is doing its thing, but the gears are not engaged even though the lever is in the correct position.
CJ8Rockcrawler
The FABLED 8
Minneapolis
MN
Disconnect power or tap it with a dead blow hammer? Seems like something is stuck or needs to be reset to me. That or the lever itself is broken.
I was going to say smack it with something to see if the guts are stuck. May just need a disassembly/cleaning/reassembly. Worth a call to Warn probably.
