What are these? Can I remove them?
distinct
New member
Friday Harbor
WA
New to the forum. I have an 85 scrambler that I am rebuilding. Motor is out and am trying to cleanup the wiring. Installing an hei distributor,Weber 32/36. I have removed the computer under the dash and all the diagnostic wiring but left with some things I’m not clear about. What are these? Any help would be appreciated
distinct
New member
Friday Harbor
WA
Thanks. Checking against that, it looks like the third photo is the heater relay. 1 down.
Hoover
Bronzed Member
Livingston
AL
Yep, the relay goes to the intake manifold heater, which is a good system to keep IMO. In your first image, you only need to keep the e-choke wire in that connector for your Weber post nutter. Also, removing all computer related wiring will make the wires in the 4th image go away as well-
