What is the best replacement for front fender to buy?
don87401
Farmington
NM
Found my big "how did I miss that" in my CJ6 project yesterday. Need to replace the right front fender. Knew it had been damaged but never tried to fit the flare. Its not going to work so back up and get a new fender. What is the best brand to order or does it make a difference?
walkerhoundvm
Just trying to stay upright
Cave Creek
I would try to find OEM, it will lessen the headaches. Most of the aftermarket ones all come from the same place - the factory in the Philippines, as far as I'm aware. They're all just branded differently.
Ron84cj
West Bend
WI
I very much disagree. I went through 4 sets of "mint" original fenders and not one was any good. They all looked great with no bubbling or rust until they were media blasted and revieled rust/pinholes everywhere. I ended up buying new aftermarket ones as a "buy it now" on eBay. Comparing them to the originals side by side I absolutely could not tell a difference. They fit perfect.
AJ2393
Scrambled in the Head
Westport
MA
Cannot agree more with going OEM. I went through many aftermarket fenders on my 81 restoration. None of them fit right, holes didn't line up, and it seemed to be a lighter gauge metal. Now, I did have to go through a few OEM ones to find a nice solid rust free one, but it lined up perfectly. Remember the hole front clip is dependent on how the fenders fit. If they don't fit right the front grille wont be straight and you will chase your tail trying to make it fit correctly. Again, this is my opinion, others may disagree.
walkerhoundvm
Cave Creek
Seems like you might have good or bad luck with whatever route you choose.
You may have better luck with rust in our areas?
I decided on aftermarket just to stay away from rust, but we had a terrible time getting them lined up. They're still not perfect, but as good as we can get them.
Rosco1974
West Haven
UT
The aftermarket ones I bought fit well, but the passenger side flare area was not fully stamped. They sent me a replacement and same thing. Drivers side was fine.
don87401
Farmington
NM
I ordered an after market I will see how well it fits and looks, may put out a call to the locals and see if any onehas on laying around in case the new one is not good.
