What new steering box upgrades have you used recently?
muelleski
Middleobro
MA
I read about the H1 and ordered one on Summit after 3 months they sent me a refund and say they cant get one. Is there anything else anyone is using new that is a bolt in for an upgrade?
Belizeit
River Ridge
Maybe find an old used one from a junk yard or online and have it rebuilt. Several years back I had one for my old suburban rebuilt and worked great
Ron84cj
West Bend
WI
I bought my h1 steering box on rockauto.com about 4 months ago. And yes, it really does just bolt in with zero modifications. It looks like they currently have one left. Get on it!
walkerhoundvm
Just trying to stay upright
Cave Creek
It fluctuates every day, and I can't make sense of how quickly they disappear and how quickly they show back up again. I checked a couple times a day and I'd get one loaded in my cart only to have it disappear. I finally got one of the Lares branded ones. I think it should bolt up but I've heard it might take some trimming.
Ron84cj
West Bend
WI
The lares brand is the one that I got. Everything bolted right in for me with no trimming involved. The variable steering is great!
walkerhoundvm
Cave Creek
I've read they were using a non-H1 source for some of their rebuilt ones, which required a welded tab or something (i.e. they had already done the welding). :shrug:
sevensandeights
sevensandeights
Mckean
I just bought a Lares 1230 unit from RockAuto for $200. It is listed as stock for Jeep CJs but is the "rock crawler" version compared to the 1231 part number. I live chatted with the Lares people the other day and they said the 1230 has a larger piston and case for bigger tires. It has the same dimensions as the Lares 1430 unit for the H1. The only difference is that the 1230 is 3.5-4 turns lock to lock verses the 3.5 turns for the 1430. The Lares rep said the 1430 unit does not have a variable ratio.
Plan to install mine this weekend.
OGRES
Ramblin' Wreck
Suwanee
GA
Do the standard hoses hook right up to this unit?
I need to do something about my steering very soon (leaky hoses) and I figured I might as well upgrade while I am at it.
FLCJ8
Palm Bay
What is the plan for the core, will your old one qualify for exchange?
sevensandeights
sevensandeights
Mckean
I can't tell you for certain because I don't have it yet but I would certainly hope so. It's listed as a stock replacement on RockAuto and the Lares rep didn't mention anything about that. The H1 and stock 1980 and up CJ should all take the same metric o-ring style hoses.
Ron84cj
West Bend
WI
Here is my H1 box installed from rockauto. No trimming or any other drama. Bolted right in with what I had already there. As for the core, I sent in the one from my cj and they took it without giving me any grief.
sevensandeights
sevensandeights
Mckean
#16
Will do but the info I posted came direct from Lares. I never claimed it was an H1 box - but based on the conversation it seems like it could be. Not sure how they could get a larger piston in the OEM housing. By "stock for CJs" I simply meant it bolts in with no modifications to the mount or lines.
It will be here Friday so I'll let you know.
Ron84cj
West Bend
WI
#17
Here are the boxes side by side. The Piston is bigger and it definitely has the variable steer. I have the H1 lares 1430 box.
