What parts from other AMC's also fit Scramblers?
Flatie46
Russllville
TN
Let's say your walking through a junkyard looking for Jeep parts. If I don't see much Jeep stuff but I happen up on a Gremlin or a Spirit, or a Concord or any other of the AMC cars, what are some parts that are essentially the same as Jeep parts? The drive train is a no brainer, just want to make sure I don't miss some good stuff I could use.
Domin8
Scrambler Enthusiast
Astoria
NY
Lock cylinders? Original AMC branded keys? Not likely to find in a junkyard, just the first thing that jumped into my mind, but then again, it's pretty empty in there!
Flatie46
Russllville
TN
I read somewhere that the radio was the same on one of the cars, don't hold me to this but I was thinking it might have been a Spirit but I can't confirm this. I know the CJ radios have to be kinda thin due to the close fit of the gauges above them. If nothing else the knobs and face plate may be the same.
East Norriton
Delay wiper setup is probably the same. (80's Bronco setups looks the same but do not work).
jsteed
Seattle
WA
Texas, when you say "plugged right in" did you already have a delay setup or did you plug it right into the existing harness and it has the delay built into the switch?
East Norriton
You get the switch and a "delay" box and it plugs right into the motor. You need the proper wiper motor though. Gotta have the right # of wires.
Ron84cj
West Bend
WI
Yup, that post was from me. The radio from a spirit is the same as a Jeep radio. It looks different at first glance because of the different/taller faceplate. The cj faceplate bolts right on. I did this in my 84 scrambler.
DeLuke
Dallas
Some of the late 70's / early 80's AMCs with floor shift automatics use the same plastic shift boot, rod and knob as the Postals and Overlanders. Worth some money for these owners. Some interior knobs are the same. Probably other random stuff, too.
TexasAg77
S.O.A. Charter Member
Cleveland
TN
Sorry I am late replying. Don't get on here too often anymore. It plugged right into the harness. Literally a plug and play deal.
