Won't idle at stop ligjt
Frenchy
New member
Amarillo
I got an 81 scrambler that I bought new my problem is when I drive from point A to point B and stop at a light it dies put in a new carb kit everything adjusted new vacuum hoses etc anyone have any ideas
walkerhoundvm
Just trying to stay upright
Cave Creek
Could be a vacuum leak, at the intake/exhaust manifold for example. I assume the carb and vacuum hoses were done in an effort to fix the stalling, and not something that happened before the issue started?
walkerhoundvm
Cave Creek
Hot, cold, any temp in between?
Fuel pump, fuel filter and filter orientation with appropriate return line (to rule out vapor lock) is where I'd check next. Then on to plugs, distributor, and timing.
Belizeit
River Ridge
What condition is your timing chain and sprockets in ? Mine were very worn and loose years ago and mine was doing the same. Ran ok until I pulled up to a light or stop sign and just die.
Frenchy
New member
Amarillo
I'll check those out thank you
Frenchy
New member
Amarillo
I'll check them out, thank you
