WTB: Clean CJ8
SeaJay7
Old Lyme
CT
Looking to buy a stock or lightly built CJ8.
Anywhere in the US is OK, prefer south due to rust.
manual or auto. prefer 304, but not set in stone
Located in the North East Rust belt :( and not much is locally available.
few questions:
1. Any that you know that are available and fit this discription
2. any transmissions or engines i should run from?
3. anyone ever buy from EBAY, seems shady, but it appears that there is come protection for the seller and buyer
Chris
Ron84cj
West Bend
WI
Scramblers never came with the 304, but are easy to swap in. In the automatic world as far as I know the 904 came behind the 4 cylinder and the 999 came behind the 6 cylinder. The 999 is the stronger of the 2. In the manual world stay away from the 5 speed "T5" unless you are staying stock and just want one to cruise with. The T4 4 speed has a similar looking curved shifter. That one is also junk. The T176 4 speed had a straight shifter. This one is a good trans. But honestly, I'd be more concerned about the condition of the body and frame. If you find a really nice one with a junk drivetrain. It's a lot easier to swap something in than to deal with body and frame issues.
SeaJay7
Old Lyme
CT
Great advice. thank you. I have seen a bunch with a 304 so i assumed they came that way.. need to read up more on my history. swapping out an engine seems a but overbearing for me, i guess if its mostly "plug and play" i have enough technical know-how, but seems like its above my abilities.
This will be a weekend driver to and from Marina/Church/Grocery store/etc and the occasional mud pit / light trails in New England.
Chris
White Rock
NM
few questions:
Chris
Whats your budget Chris? I thinking very hard about selling mine which is lightly built (see the footer).
SeaJay7
Old Lyme
CT
Nice! We'll be eagerly awaiting photos.... :thumbsup:
i am eagerly awaiting her arrival and see what i bought :)
always fun to determine what changed over the last 37 years since she was build...
I KNOW she has:
V8
3 Speed manual
No doors or Hardtop/bulkhead
New seats and rear seat
other than that.... shes going to surprise me
AK-RWC
south central
AK
#16
Soooo what do I have :)
Not sure you're actually asking a question or not, but if you are, here is my analysis based on the photos in this thread and the other one:
You have a base-model CJ-8 that was likely someone's pseudo-restoration project at some point. The frame looks reasonably clean, which really is what counts as much or more than anything else, but there's been at least one major frame repair at the front left spring hanger, so it'd be worth taking a close look elsewhere for further cracks and rust damage. I'd probably start at the rear and work my way forward tapping it with a hammer and listening for thin spots, as well as looking for cracks and places where the C-channels may be trying to split. That being said, the bent spring at that location (front left) suggests that the frame repair (which looks amateurish) could be from an accident. I'd at least stick a bottle-jack at that bent spot in the spring and bend it straight (and I'd keep running the spring; I've done this a couple times on different Jeeps with great long-term results). It's had at least one obvious patch-panel installed for the passenger floor, which means there are probably other patch-panels. The tailgate is aftermarket. The body mounts look like they've been off not too long ago, which is also a good sign. It has the smaller (steel) fuel tank. It has obviously been repainted, and bedlined. Someone added a tach, which from the photo I can't tell if it's an OEM tach or an aftermarket tach, but either way it was not original to the Jeep since if you got the OEM tach, you also got the OEM clock. But considering that it's a 304, the OEM 6-cylinder tach wouldn't have displayed the correct RPM anyway. So, on to that 304. You should check the casting in the block, but given the t-case shifter and the fact that it's a 3-speed, I agree with your earlier assessment that it's a T-150, and the t-case is probably a Dana 20, so the whole drivetrain probably came from a '76-'79 CJ-5 or CJ-7. (It's also possible that you have a T-15 (or even a T-14), which would have been between a 304 and a Dana 20 in the early '70s.) The engine was repainted some other shade of blue, probably when it was stuffed into this frame; or even earlier (the upper portion of the bottom of the oil pan is the original AMC blue). It does not appear that you have the electronic ignition since I don't see the harness for it from the distributor, which suggests that you have a slightly earlier engine; I think the Motorcraft ignition became standard in '77, so you might check the left fender for the ignition box and/or pop the distributor cap to see if you have points. I also see the earlier style air-cleaner rather than the one that is squared at the end for connection to the grill for fresh air that would have come from a '76+ CJ. The seats and wheels are aftermarket. The stainless mirrors, grill, hood accessories, and grab-bar are aftermarket. A PO welded up custom front and rear bumpers using big angle-iron. The front shackles are a nice aftermarket replacement. The exhaust is obviously custom. The dash-pad is for non-vent doors or soft-doors. You're missing the driver's side grill support, but it looks like the bracket is missing from the firewall (I'd actually weld the bracket back to the firewall and get a replacement).
My overall assessment: this is a great little project Jeep for you! It's had a cosmetic restoration not too long ago, so as long as the rust-monster was reasonably put at bay, this will be perfect for your plans. It's not so "original" that you should feel bad modifying it at all. In fact, this is probably the PERFECT Scrambler if you DID want to modify it. But the mods that were done are pretty authentic and still "true" to AMC with the AMC V8 with the Jeep drivetrain and some basic body-work. The 2.5" lift and 33"s will make this extremely competent in the woods, and with the 304 you'll have plenty of power to turn them even if you don't change gears. So long as that crack wasn't from some accident that totally screwed up the frame, this is a great little runner that you can have fun with, that still has room for upgrades as you see fit.
SeaJay7
Old Lyme
CT
#17
Exactly the assessment i was looking for!! thank you! I will dig into the frame tomorrow and see what else i need to be worries about.
THe springs are going to get swapped for a 2.5 lift in short time. (pending frame concerns)
this will not be a "restoration" it will be a mild build for family weekends and some light trail rides in New England.
Chris
Kane
Berlin
ct
#18
Old Lyme. I am up in Berlin CT about 30 minutes from you. If you get this on the road in time take it to the annual Great American Jeep rally in Ellington CT on September 15th. I will have mine in the classic section. I was one of 2 Scramblers out of 1300 Jeep last year. We can park next to each other and talk Scramblers all day.
Click on this Jeep Rally
SeaJay7
Old Lyme
CT
#20
Awesome!!! I wont be ready by then but for sure lets stay in touch! She delivered this morning so i am finding some "surprises" already haha
