More progress
Since last week I've done a few things here and there, mostly working on little things that have been bugging me:
1) Windshield wipers work, but the fluid reservoir was cracked at the base and the pump was rusted out. I ordered a replacement from oconee off-road on eBay, great people to deal with, great prices (and about $12 cheaper than Collins bros):
http://cgi.ebay.com/ebaymotors/Jeep-CJ-CJ5-CJ7-72-86-New-Windshield-Washer-Bottle-Kit-_W0QQcmdZViewItemQQhashZitem5888114129QQitemZ380239954217QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
If you've installed it and there still isn't a stream coming from your nozzle, make sure you have the leads on correctly, otherwise it tries to blow air into the reservoir
While shopping with them, I also picked up a replacement heater diversion attachment, to get the heat to the feet so to speak:
http://cgi.ebay.com/ebaymotors/New-Jeep-CJ-CJ5-CJ7-YJ-Wrangler-78-95-Heater-Lower-Duct-/380236703330?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item5887dfa662
That was quite a PITA to put in. I wouldn't wish that on anyone.
2. I have courtesy lights installed, but they weren't working. After some checking around, I realized they have a fuse for them, which was blown. Replaced it, now I have working courtesy lights! Problem is, either I have an older model switch or my stop-check is broken, because you can rotate the switch all the way counter clockwise and the lights just come on, there is no "click" that lets you know you've turned them on. Maybe someday in the future I'll worry about getting a new light switch, but word is they're more of a PITA to put in than the heater diversion.
3. I only recently noticed my back-up lights weren't working. After figuring out where the switch was mounted in the tranny, I followed it all the way back to the fuse box, cleaning the single attachment on the way there. Followed the lead all the way back to the tail and checked the grounds. Everything looked OK. Then got wise and checked the fuse - you guessed it, blown.
You may be noticing a pattern here. I have a problem fuse box that I need to find some way to support to the firewall until I can get a new harness...that I think will happen sometime next spring when I've saved up enough to get the tub off, sand blasted and repaired. At that time, I'll also swap out the old floor panels for a new complete panel. Once that's done, she'll be getting the new harness.
4. Finally, she came with the manual turn-signal correct option from the previous owner, meaning when you completed your turn, you had to manually reset the turn arm. In my case, it was only left-hand turns, but I was starting to feel like my old man driving down the road all the time with my turn signal on, so I decided to go after it.
I followed the instructions here:
http://www.epiccomputer.com/dale/jeepjunk/tilt/tilt.html
And I went with a lock plate removal tool despite the NAPA guy telling me I wouldn't need one - I did.
Now, there might be a couple of things going on to make your turn signals not cancel. On the above site, he had a broken turn signal cancel cam. Unfortunately, that wasn't the part I ordered from NAPA, despite the guy telling me that what I had ordered is what I needed to fix the problem. Fortunately, my cancel cam was in good shape. However, that left me with another issue that the cam I ordered didn't fix:
Those little hairpin doohickeys are known as control springs, and one of mine was missing. If you run into the turn signal cancel not functioning and you order up a new cam, make sure these come with it. I had to run back and forth to the parts store twice - once to buy a new kit with the springs, and another to return the old one.
Here you can see both springs in place:
I put a dab of lube under the little metal fulcrum at about 430 on the dial in the pic, so there wouldn't be friction forever. The old one looked like it had some lube there from the factory, so thought it was appropriate.
Took her for a spin, and walla! Functioning turn signal cancels!
So what's next? Well, the body repair is a long ways off, until I can save the money to have the whole thing done right. I think I nearly have her where I want her leading up to that point, though. The only thing she does need is a new set of front seats. I'm thinking about these from Q-tec:
http://www.quadratec.com/products/24215_1XX_PG.htm
Unless I hear any differently from someone...
One other thing I came up with - my grab bar is without leather
Here's what I came up with: I ran into a 3' rattle snake yesterday while out riding. Let's just say he wasn't too happy to find out his fangs were useless against 2.1" mtb tires. I now have a nice looking skin that I'm trying to find something to do with (and about half a cup of rattler trimmings - tacos maybe?) .
If I had any leather working skills, I'd try to incorporate it into the grab bar, alas...Any ideas out there - are there professional leather workers who could do this? Seems like it would be pricey, but I bet I'd be the only one out there with a rattlesnake hide grab bar cover!
Until next week...
