Cheep 8 Project
Stouttrout
Registered Jeep Nut
Sour Lake
Tx
Not so "Cheep" 8 Project
Well, the tear down has been started. I thought I would run a post here to keep track of it and I am in hopes that some will provide advice. If you see anything I should or could do, PLEASE let me know. The plan is to paint the body, undercoat it, Spay in bedliner the inside, Treat and paint the frame, and install a 350 Chevy engine / 700R4 combo. I have been working alone on it so it takes a little while. I do have a really good gopher that I must give a lot of credit too, my wife. I had help removing the Tub on Sunday. The first day I spent Nine hours tearing it down and getting it ready to separate. I removed the engine, tranny, Tcase, driveshafts, and most all the inside guts as well as everything hanging off the fire wall.
Day two I removed all the body mounts and everything connecting the tub. Then we began removing the tub. I use the word "BEGAN" very loosely here. First of all it is heavier than I thought. Second, well lets just say about two hours later my trust assistant and I had it separated.
Now the clean up begins.
forum
Awsome. My suggestions to you would be to use silicone when bolting pieces of metal together like the hinges, tail lights etc. to keep water and dirt out. It is all to common for rust to start in these places first. Good luck.
Kind of makes me wish I was in Texas. I'd be glad to help you and maybe in the process I'd get some much needed Jeep education. Good luck.
Congrats on getting the tub off. Sounds like you have a great assistant also. :D
Keep us posted on the progress.
I guess this would be a bad time to tell you that it would've been easier to remove the tub first, then the powertrain ;)
When you reassemble, put the powertrain in first and just set the tub in place to check clearances and set final positioning before making the engine mounts permanent.
DrNightStocker said:
Awsome. My suggestions to you would be to use silicone when bolting pieces of metal together like the hinges, tail lights etc. to keep water and dirt out. It is all to common for rust to start in these places first. Good luck. BTW, I wouldnt use Wesson oil as assembly lube.
I thought about using the silicone but did not want it to stick to the new paint. A buddy of mine who work on small planes gave me a good hint. What they do is oil some wax paper with mineral oil and lay it on the body, The they mount the hinge using silicone between the wax paper and hinge. After 24 or 48 hours they pull the hinge back off, pull the wax paper off, trime the silicone ooze and they are left with a nice silicone gasket. And, you are right Wesson is loosy assembly oil but their peanut oil sure can fry the heck out of a turkey!!!
Yes it would have been. Unfortunately, the muscle was not there. My helping hand was at work. The body lift provided enough clearance. Just enough.:D
I never had any problems with the silicone sticcking to the paint but I think your idea is better in many ways, I imagine it would ease in the adjustment of hinges etc. as well as give a more sanitary look. Thanks for your feedback. Oh, make sure you do the body to frame mounts, you may want to use por-15 or something first.
Remember if its broke fix it, and if it aint make it better.
Wow time passes quick. i thought I would post a whats up with the project.
I ended up breaking it completely dowm. More work than i expected but i think it will be worth it. I had the fram blasted and painted but the paint sucked the balsing guy was an A$$ and basically I am out the $150 it cost me.
I found a another business. He does alot of the plant work in the area. He is very reasonable and seems to know what he is talking about. He set me up with a Galvanizer. He blasts and paints Galvanizing all the time and explained the process to me. he even showed me several peices of his work. I guess he felt sorry for me since I had been ripped off by the other guy. He is going to re-blast it, send it to the galvanizers and then re-paint it for me. I will get it from him tomorrow. I have a couple things to do to it before it gets galvanized. All in all it will cast $200. i should have done it in the first place.
The engine is complete, tranny is done. paint is lined up to start next week. I hope to be done with this in the next month or so. I will post some pics soon.
Thanks to everyone giving advice and lease keep it coming.
Dan
No kidding about the time passing quickly. I'm 6 months into my project and I still haven't primered the tub. I've been piddling around with seat brackets, sanding, primering, re-painting. I need a kick in the a$$ to get me going again. The weather in Dallas has been sucky for the past month, either too windy or raining cats and dogs. I'm hoping to shoot some primer this weekend (fingers crossed).
Hey Baldwin, get it primed yet? Almost another month has passed. I finally got my frame back. Wow!!! I strongly recomend galvanizing it. Way cool. make for a life time frame. it ended up costing a little more. here is a cost break down.
$75 to blast the frame
$50 to Galvanize ( BARGAIN )
$200 to treat and coat the galvanizing to a semi gloss black
Total: $325 for a frame that will last forever.
I could have stopped at the galvanizing and not top coated it but did not want a grey frame.
The reassembly finally starts again.
I still want to upgrade the Axles on it. Just to D44's I have no idea where to start or how to do it. Right now I am going to put the old ones back on but wold like to get the axles built before I have it completly assembled.
Any advice? Can I use the front and rear out of an old Ramcharger? I think they had a 9.25 for the rear and a 44 up front. They also had the 5 on 5.5 I am looking for. What gears? I have 33's now and might move up to 35 in the not so near future.
Dan
Finally!!! The chevy 350 is in. not quite as easy as I had hoped. I should have some picks up here tomorrow.
Cool THread
Dan,
I'm really enjoying your thread, watching your progress (learning and taking notes). Keep up the work! And good luck with the completion of your project.
-Travis
Thanks MudEgg. I appreciate the vote of confidence there. Here are some more PICS.
This is the frame, Bare just after getting back from the Galvanizer and recoating place.
