Dan,
Are you replacing the stockers because they have sagged? If so, it would be a good time to go with lift springs. Do you wheel at all? If so, you could use that lift. If it's just a daily driver not used for any hard core wheeling, consider replaing the stock springs with replacements from JCWhitney. About $69 per spring set (each corner) Go to JCWhitney.com for more details. I've used their springs for years on my SOA's.
It would require some fabrication and moving of spring hangers to use YJ springs. I've done this on the front by cutting of the rivet, and moving the front hanger forward to the next bolt hole. Straight replacement would be the easiest and cheapest.
'80's CJ springs: 45" long/frnt:2" wide, rr: 2-1/2" wide
YJ springs: 45-1/2" long/frnt: 2-1/2" wide, rr 2-1/2" wide.
JCW has some H.D. 7 leaf springs/double wrap ends, that I've used and like a lot. Just remove the flat overload spring.
regards, as always, jefe
