B
BritScrambler
Guest
As the time draws near for our Moab National Event I thought it to be a fitting time to start to describe the main events...the trails! This will be a series of trail descriptions. Feel free to add your comments, especially those of you that are familiar with these particular trails. Better still, would be if some of you could also add your photos.
It needs to be stated that the descriptions below are a GENERAL description of the trail. Of course the exact route(s) are up to your Trail Boss(es).
The following trail descriptions are taken from the “Moab Jeep Safari” publication by the Red Rock 4-Wheelers (with a few minor modifications, mainly deleting references to EJS specifics)
Extreme:
Friday= Moab Rim/Hells Revenge
Moab Rim:
The Moab Rim is the cliff rim seen just to the southwest of town. Its only four-wheel-drive access begins just downriver from town and the first mile has about the highest density of obstacles of any of our trails. Many vehicles have “bit the rocks” on the succession of rock ledges and tight turns that lead to the rim. On top, the trail is sand and rock as it leaves the rim. A spur, sometimes used, visits Indian ruins and rock art. After closing a short loop, the trail returns on the same rocky mile it started with.
Near the top of the first mile, signs will show that private property is being used; please respect our privilege to use it by staying on the trail. Approximate mileages: 12 total, 7 off highway.
Scenery: The first mile of trail follows the slope of the titled rock layers and has increasingly high overlooks of the Colorado River gorge in one of its most beautiful areas. The rim view includes the La Sal Mountains, Moab, and Spanish Valleys, some of the Arches National Park and distant features such as the Book Cliffs. Behind the rim are displays of rock domes and fins and some of the rims of the Colorado River gorge farther downstream.
Road Surfaces: The first part of the trail is mostly on bedrock that nature has broken into ledges and steps. The higher country has slick rock, blow sand, and some sandy dirt with broken rock mixed in.
Obstacles: Highlights amoung the many steps in the first mile are Devils Crack and the Z-Turn. The former requires a tricky turn onto a ledge to avoid dropping a wheel into the creack beyond, and the latter has two turns over irregular rocks and ledges. On top, a slick rock dome has an optional climb with about 85 percent grade!
Hells Revenge:
Our premier slick rock trail lies northeast of town between the Sand Flats Road and the river. There are long stretches of slick rock where the 4WD trail has recently been marked (a yellow, sometimes white, paint design that resembles a flame). There are other paint marks too, for mountain bikes and emergency medical services. The most difficult obstacles are out of the stock-vehicle class, but those can be bypassed. There are steep climbs and descents and some edges that are not for the faint of heart. The steep slopes, however, are not technically difficult because of the excellent traction on sandstone. In a few places, the trail crosses the now-famous “Slick rock Bike Trail,” a motorcycle and mountain bike trail (although the Lion’s Back, the Dump Bump, and Potato Salad Hill are nearby, they are not part of this trail). Approximate mileages: 16 total, 12 off highway.
Scenery: The large vistas sweep full circle from the La Sal Mountains through Arches National Park to the cliff rims that overlook Moab Valley. The nearby country is an amazing stretch of bare sandstone with clefts and canyons, including the Colorado River canyon.
Road Surfaces: In addition to the slick rock, there are rock ledges, broken rock, sandy dirt, and a little blow sand.
Obstacles: The first clump of slick rock has high mounds and steep descents that lead to a second mound that does the same thing. The major slick rock area includes steep climbs, sharp turns, and a hair-raising decent!...Along a steep ridge with little room for error left or right. “Tip Over Challenge” is a brief rock hill with a sandy base that requires tight maneuvering, and excellent line of attack, some help in the differentials, or the easy bypass on a slick rock fin. Just above Tip Over Challenge is a shortcut to avoid the final hill, called “Rubble Trouble” because of its large loose rocks and a couple of tough ledges.
Still haven't sent in your registration??? REGISTER HERE!
Extreme:
Moab Rim:
Hells Revenge:
