weight and exact size of steel tub??
Bad Karma
Captain Sarcasm
Cobourg, Ontario, Cana
da
i'm possibly buying a CJ-8 tub off of someone on the other side of the country and i'll need it shipped.. i need to know the ball park weight and the dimensions of the tub so i can get a semi accurate shipping cost..
any help would be greatly appriciated...
or if anyone is driving from WA to Toronto Canada... :D
Somebody may be able to come closer, but I would guess just the tub weighs in about 250-300 pounds, 400 max. When I was doing the frame off, it was a struggle for my daughter and I to turn rotate it.
For size, I just messured mine at 60 wide, 118 long, and 30 high.
i got a repitub from willys overland if i remember right it was approx a buck a pound for shipping and the shipping was $409
cj7fun said:
I put a totally stripped OEM Scrambler tub on a set of Longacre Racing scales at work today. The tub was literally bare- no tailgate, no rollbar, no tailgate brackets, no dash, no steering brackets, no heater duct, nothing but the steel body. This tub is completely intact, solid, no rot spots. Weight = 282# I was expecting more. Weight with the tailgate, tailgate brackets, and accelerator pedal was 304#.
from another post
Check the YTMag tractor site for good shipping. Often there is someone moving stuff with a partial load and you might be able to get on one of those trucks. Shipping will be in the $4-600 range.
I was looking into getting an Aluminum tub sent from western canada to virginia and it was in the $550 range, and they had been having a lot of trouble with damage on their tubs.
If you can afford the price it woudl be ebst to drive down to Ohio and pick up a Repi-Tub from Willis-Overland. They can ship too.
But if you got to have original steel I can understand that too.
Carl
