Change lube in SR 4
sxer
Long Prairie
Mn
This is probably a stupid question, but how do you change the lube in an SR 4 transmission?
I can't find a drain plug in the bottom, but there looks like there is a boss where a a hole could be drilled and tapped for a pipe plug.
It is mated to the 300 transfer case in my '81 scrambler.
What is the recommended fluid?
Thanks
Bob
I had the SR4 in an 80 CJ7, the drain bolt is the lower drivers side tranny to engine mount bolt...it sucks! its ahrd to get to and makes a big mess!!! I did ask a local jeep mod shop if a drain hole could be added and was told it could but it is HIGHLY discouraged!!!! infact they refused to do it. said if I wanted one to do it my self. And this is a shop that is very capible and willing to do almost any mod.
I cannot remember the fluid type, I seem to remember ATF, But dont know for sure, any tranny shop would be able to tell you
Thanks for the reply.
I'll check it out today.
Bob
Here is a picture of the drain bolt. It does make a mess if you don't remove the transmission mount/skid plate.
The Haynes manual calls for 75 W 90 GL-5 lube.
Also a picture of my shift knob. I'm thinking of doing some rat rod stuff.
Bob
