Your prefered CJ8 tire size poll
Based off the most common five tire choices which do you prefer for your CJ8?
  • Total voters
    319
Im running 37's, they are a good compromise for me when wheeling & running around town, with a SOA's I didnt need a body lift or high lift springs, anything smaller just doesnt look right not filling out the guards IMG_3605 compressed.jpg CJ8 Camp Coffs 2015 day 1a (4).jpg
Thanks, I reset the springs yesterday now it doesn't sit low in the back
that is a good looking Jeep and the 37's look right for the lift and flairs.
Finally "finished" for a while. 2.5" BDS suspension lift. 32X11.50 BFG MTs. New front and rear axles with 3.54 gears. Warn hubs.
They are NT. They came from a CJ7. I say "new" but they are used. Had to use 1.25" wheel spacers for turning radius. Tires are flush with wheel wells, which is what I was going for.
Favor to ask. Would you mind posting a pic of your front hubs? From what I can tell in this pic it looks like you have the OEM center caps on there. Does that work for you because you put the Warn Hubs on? It certainly doesn't work for me with spacers and the OEM hubs. If so are the hubs inset from the opening on the center cap?
Doesn't look like he has caps on it to me.
I recently swapped a stronger 6 bolt hub setup to the 5 bolt hub setup so I could run my OEM center caps, but I'm only running 31's and have never had a Warn (aftermarket) 5 bolt hub break so I felt the 6 bolt hubs were overkill.
If you want to run 6 bolt hubs the factory centers won't work. I've got early chrome Warn hubs on one Jeep and Superwinch on the other and both work with the OEM center caps.
If I had known the 5 bolt would have worked with the caps I would have used them. breal- I had a gap between hubs and caps so I didn't use them on the front. Doesn't look as bad as I thought but like the look of the caps better.
View attachment 50643View attachment 50644
Looks really nice.
Gotcha, that makes sense. I like the look of the caps as well. I need to find a machine shop that can make some clean cuts for me so that they will work with spacers.
Kane,
Looking for advice - would like to put BFG 31x10.5R15 mounted on 15x8 wheels on my stock 1984 CJ8 (no lift). Will they fit, and is there an optimum offset?
I'm very torn right now, between Cooper 32x11.5 STT Pros and BFG 33x10.5 KO2s.
I really like the Cooper tires better, but I've been wanting 33x10.5s for a while now.
I'll post a pic next week when I make up my mind....
The 11.5 width that the 32 offers is unique and looks great on a stock wheel size IMHO. :wave:
Kim, I love your Scrambler. I hope you don't mind that I have saved every pic I have seen of it and added them to my rotation of pics for my screensaver. As for the speedo, I have the opposit. I went from the 28s to 31s and mine reads low. That is more dangerous for tickets. Where you would be the slow guy getting nasty gestures out of car windows. At least in the DC metro area.
I have been thinking about a small lift and 33s, but for the reasons that you mentioned, I have not been inclined to do it yet. Not at a point to hit the rocky trails yet.
I wonder if these 2 ever got together & swapped speedo gears :thumbsup:
BTW, any chance on sharing that screen saver to the group :bow:
