65.5" from sidewall to sidewall. 32x11.5 on the restored 15x8 white wagons from certifiable jeep. 2 1/2" lift from BDS. Narrow track axles.
I think my turning radius has gotten a little larger, but not enough to second guess the lift/tires. There is slight rubbing.
i run 35x12.50s on factory 15x8s and narrow tracs and Spidertrax spacers. I only rub when trying to do a full lock
This is a 1979 with 15x8 on narrow track axles. Your avatar image looks amazing. Curious as to why the upgrade ? Is it that at the angle straight on its too narrow ? If so I agree that an 81 scrambler and all narrow tracks for that matter just don't look as good as the 82 and up. Looking forward too seeing what you dohave always loved that 8 !
I'm guessing you're not using factory center caps? even with the 1.5" spacers I mounted I can't mount the front wheels with the center caps without altering them. Now I'm looking for a fabrication shop That could help me make some super clean cuts to notch out small sections of the center caps so that they will fit.
If you have a different experience or any ideas I'd like to hear them as I'd prefer not to have to cut the center caps
